Where its at.
08/15/2014 at 21:35 • 0 commentsThe body of the unit is made. The hopper nears completion. The outlet section requires plumbing in to a non existent gas cleanup system. From here we need the burner, fed by pressurized syngas, providing power to the sterling engine that charges batteries. Some micro controller can monitor the whole system and assure that feed stock does not run dry.
