PCB Assembly
There's not much to report here. All parts fit correctly. I suspect ALLPCB from drilling the holes for the PCB studs a bit too large.
Pin 1 of the pin headers was not marked in the silkscreen of the PCB. This will be fixed in the next revision.
Electronics
Before connecting power, all connections should be checked. I felt confident enough to skip this step. The schematics don't contain any new circuitry to me.
Unicorn! Revision 0 is fully functional.
Firmware
The Adafruit GFX is quite nice. This will be used to provide high level functionality for drawing lines, character sets etc... I only need to write a low level driver that can color a pixel at the desired coordinate.
It didn't take too long to get this working.
Next thing is adding dimming functionality.
