1Step 1
download STL files
2Step 2
print out each STL file once except for the buttons print out 5 buttons
^ pi with screen L ^
^ shorter L ^
^ screen spacer ^
^ raspberrypi middle with 5 bottons ^
^ raspberrypi bottom ^
3Step 3
super glue case pi with shorter L with case pi with screen L
set aside for latter
4Step 4
with small screws attach raspberry pi 3 with raspberrypi bottom
5Step 5
snap together raspberrypi bottom with raspberrypi middle
6Step 6
mate raspberry pi 3 with Adafruit LCD + keypad kit
7Step 7
add screen spacer on top the the raspberrypi middle
8Step 8
flip over super glued case pi with shorter L with case pi with screen L insert 5 buttons
9Step 9
mate the raspberrypi assembly with the super glued screen holder upside down so buttons do not fall out
10Step 10
take 4x2.5in screws and thred them though all the parts in the assembly
shane bourgeois
