1Gearwheels assembly
Components list :
- 1 x Gearwheel 20 teeth
- 1 x Gearwheel 19 teeth
- 2 x Roller Bearing 8x22x7
- 6 x Screw M3x10
- Insert the roller bearing in each gearwheel
2. Screw the six M3x10
2Base assembly
Components list :
- 1 x Base
- 1 x Roller Bearing 8x22x7 with stop
- Insert the roller bearing in the base
3Head assembly
Components list :
- 1 x Head
- 1 x Needle Roller Thrust Bearing 40x60x3mm
- Insert the roller bearing and the needle roller thrust bearing in the base
4Motor Base design
This part is a costum part, you need to adapt the piece to your own motor for fixing it to the base.
5Rings design
This part is custom too, the pieces depand of your motor shaft. You need to design two differents rings in respect of the quotations below.
6Example : Motor assembly
Components list :
- 1 x Motor Base
- 1 x 7mm Ring
- 4 x Screw M3 x 8
- 1 x Screw M2 x 3
- Screw the four M3 x 8
2. Insert the 7mm ring on the shaft and screw the M2 x 3
7Base assembly
Components list :
- Motor Assembly
- Base Assembly
- 6 x Screw M3 x 8
- 1 x 14mm Ring
- 2 x Screw M2 x 3
- Screw the six M3 x 8
2. Insert the 14mm ring on the shaft and screw the two M2 x 3
8Gearwheels and Head assembly
Components list :
- Base Assembly
- Gearwheels Assembly
- 1 x 7mm Ring
- 1 x Screw M2 x 3
- Head assembly
- Insert the gearwheels assembly on the 14mm ring
3. Insert the head assembly on the 7mm ring
9Final assembly
Components list :
- Gearwheels and Head assembly
- 1 x Top
- 4 x Screw M3 x 20
- Screw the four M3 x 20
2. Insert the needle roller thrust bearing in the top
Great instructions!
but where are the step/dxf files for the custom parts?
1×Base
1×Head
1×Top
1×Gearwheel 20 teeth
1×Gearwheel 19 teeth
should we take inspiration from => http://www.zincland.com/hypocycloid/ ?
yep. got'em. thanks
