Update
I rebuilt the paged memory board and the Flash Programmer for a ZIF socket. It allows quick and easy Firmware updates.
Other than a initial glitches for the Flash Programmer (probably still wet from the solder flux solvent), it all works.
Now Where Was I?!
After a long break I have to work out where I was:
Current firmware:
- TTA8_FlashProgrammerSDPv4a
The Interpreter primitives coded:
- inline
- call
- jmp
- jz
- mov ax,[bx]
- mov [bx],ax
- push ax
- pop ax
- push bx
- pop bx
- xchg ax,bx
- xchg ax,cx
- xchg ax,dx
- xchg ax,sp
and:
- jnz_timer
- jz_sflag
Load program has been coded:
- 80 84
- 81 FD
- 82 85
- 83 FF
- 84 06 (ROM #)
- 85 00
Current programs include:
- Program 06 is an 8 Bit Counter
- Program 07 is a 16 Bit Counter
- Program 08 is Serial Echo
Basically I remember I had to revert to this version of the firmware because I messed up the serial interrupt code. So I was working on the Interrupt and Serial code.
Minor Firmware Updates
Looking at how to read/write between RAM pages. I had made provision in the CPU model but had still to update the Interpreter. Done! Now the Interpreter updates the RAM_Page and ROM_Page registers when the ROM or RAM changes. Looking through my notes I see that I have written a standard for long pointer read/writes (i.e. between pages). Currently the Interpreter can only read/write inside a page. I need to move some code around to make room for long read/writes.
I have this idea to move the Stack to a dedicated RAM page and to add a dedicated Return Stack (with its own RAM page).
Checked the Serial I/O, it works fine.
Updating the firmware is a very slow and repetitive process. I dare not do too much else I may not be able to debug the problem (been there!).
So the next step is to migrate to long pointer read/write.
Okay short and long read/writes done. Next is to move the Stack Pointer to its own RAM page.
Undated the firmware for the new PUSH/POP/CALL/RTN code. Worked first off! Updated the EMU to confirm.
New CPU Model
Considering a closer approximation to the Intel 8080:
- [IP] -> [PP][IP] (i.e. the Interpreter paged memory address)
- [SP]->[RP][DP] (i.e. a return stack and a data stack)
- [HX][LX]
- [EX][DX]
- [CX][BX]
- [AX][FX] (i.e. A and Flags)
- [TX] (i.e. Temporary registers)
With this in mind I have written MOV A,[C:B] and MOV [C:B],A type instructions where C is the Page and B is the (RAM) Address.
New CPU model updated. Test with default programs.
Where am I going with this? I am thinking a tiny Forth. The Interpreter is basically an inner loop. So I need a number of primitives, a dictionary and the REPL.
AlanX
