Main structure (of the first prototype) based on popular MakerBeam parts as well as some custom designed 3-D printed, machined and and laser cut parts. Every arm has 4 DOF, the head 2 DOF. Only digital servos with brush-less motors are used. Head consists mainly of a SunFounder 24x8 LED Dot Matrix Module called EMO. The robot base uses 2 angular geared DC motors, supported by 2 caster wheels so that it can turn in any direction and turn in its own length. Controlled by several Arduino micro-controllers, main brain probably a Raspberry Pi. Beside of how to build this robot, the project will address artificial intelligence and provide all the source codes.
More details will follow in the build logs. So far:
- Propulsion system of the robot
- Human Machine Interface
- Power supply
- Videos! UPDATED!
- Ultrasonic sensor module
- Sensor module
- Vision module
- Algorithm bits
This project is published under the MIT license.
M. Bindhammer
A lot of work went today into the vision module. I glued the level shifter into place with 2-component epoxy adhesive, wired the level shifter and the APDS-9960 breakout and assembled the module on MARB's head.
3-D printed part from Shapeways:
txdo.msk
hIOTron
RoboCircuits
oh, right. XD i saw that, idk why it didn't register.
