Get a larger cut area on the stock K40 laser cutter
UK40OB K40 Lasr Cutter Final Parts.skpSource file for the parts used on the UK40OB in ScketchupSSEYO Koan Play File - 246.86 kB - 10/07/2016 at 03:45 |
UK40OB final parts.svgsvg for the parts used on the UK40OBsvg+xml - 448.62 kB - 10/07/2016 at 03:45 |
Cut the parts to be used in the assembly. Else how are you going to assemble the new parts? :)
Remove all the internal of the original K40 laser cutter
Measure and make the holes on each side of the case
Hi, I really like the simplicity of your modification.
I started to dismantle mine and would like to know the lengh of the 20*40 rail you ordered.
Thanks in advance,
Asmo
Thanks mate nice hack!
