Korg NTS-2 Oscilloscope
05/10/2022 at 18:12 • 0 commentsLooks like a neat little scope https://www.korg.co.uk/products/nts-2
4-channel oscilloscope
With dual stereo inputs, you can study up to four signals at once, comparing and overlapping them with ease. A variety of display modes let you see your data in colour. Its user interface is clear and quick, thanks to dedicated menu buttons and clickable encoder knob.
FFT/Spectrum analyser
NTS-2 comes with a dedicated FFT (Fast Fourier Transform) mode with a real-time spectrum analyser. These handy tools have always been out of reach for the synth musician - they either required expensive hardware or a computer nearby. Now you can carry them in your pocket!
Dual waveform generator
A flexible Wave Generator mode makes NTS-2 much more than an oscilloscope. It has two oscillators with dedicated outputs. Each oscillator can create a variety of waveforms – sine, square, triangle, sawtooth, pulse, and noise – whose shape and phase can be adjusted to suit many applications.
These sounds can be used in the audio range or as control voltage sources, and they can be set to cycle continuously or act as one-shot impulses; that means you can turn them into LFOs, envelopes, triggers, and control voltage generators, as well as sound sources. Attaching the NTS-2 to any patchable synthesizer instantly expands its power in useful ways, making it an analogue synth player’s dream tool.
Tuner
NTS-2 wouldn’t be complete without a precise and easy-to-use Tuner with multiple display modes!
Resident @ The Laundry SF Jan 8, 2019
01/08/2019 at 21:07 • 0 comments![]()
Tonight at 8pm, and every 2nd Tuesday of the month.
DIY Eurorack Ableton LINK Module - CLK / RST Generator
08/08/2018 at 21:29 • 0 comments![]()
spink0 uses a Rasperry Pi Zero W and connects your eurorack to an Ableton Link network.
The spink0 is a patchwork from shaduzlabs pink-0, a CLK / RESET generator based on the Rasperry Pi Zero W. His source code is the core of this project. After a lot of tweakin, tuning & changing, a working LINK connection could be established.
https://github.com/seismicindustries/spink0
Modular Synth Discussion @ hac.io/CvRy -
Alternate O_C Firmware Hemisphere in Development
06/25/2018 at 22:32 • 0 comments![]()
Modular Synth Discussion @ hac.io/CvRy 'Hemisphere splits O_C in half. Each applet gets half the screen, two digital inputs, two CV inputs, two outputs, one encoder, and one encoder button.'
https://butmostlycrime.blogspot.com/2018/06/introducing-hemisphere.html
Resident Open Mic @ The Laundry
06/13/2018 at 21:31 • 0 comments![]()
Modular Synth Discussion @ hac.io/CvRy ![]()
Large Pittsburgh Modular case and a whole lot of other hardware and controllers.
More from Resident.
Control Voltage + Cat
06/12/2018 at 19:11 • 0 comments -
June Modular Synth Events - San Francisco
06/07/2018 at 21:45 • 0 comments![]()
Modular Synth Discussion @ hac.io/CvRy Church of the Super Serge at Robotspeak June 9th
Resident Ope Mic at The Laundry June 12th
AI Synthesis Podcast About DIY Synths
05/30/2018 at 20:37 • 0 comments![]()
Listen to the Podular Modcast with AI Synthesis. AI Synthesis has DIY synth module kits and more. "All modules are wiring free, have free schematics, full how to build videos, feature easy to solder pads, and instructions that teach you how the circuit works."
Synthesizer Noise Sources
05/15/2018 at 16:16 • 0 comments![]()
Noise can be used for modulation or to process with other sound sources. There are plenty of modules that generate noise. What are some non traditional noise sources?
FM/AM radio tuned between stations
Smartphone apps for noise generation
WiFi signals turned audible
Arduino noise because everything needs an Arduino
Modular synth Patch & Tweak book on Kickstarter
05/14/2018 at 15:19 • 0 comments![]()
Looks like a nice book with eight days left to support. Also check out the interview with DivKid and some of the authors of Patch and Tweak.
Richard Hogben
