1Step 1
Wire the filament of the rectifier tube to the negative output of the piezoelectric crystal.
2Wire the top plate of the tube to the negative terminal of the microwave diode, then wire the positive terminal of the diode to the positive output of the piezoelectric crystal.
3Pull the trigger and watch your radiation detectors click.
