A small log to note that the current master branch for ST's arduino core now supports Malyan's M200 V1 and V2 (and possibly delta/M100). I am extremely limited in hacking time at the moment, but it's in.
Go forth, build Marlin, and enjoy.
A project log for Monoprice Mini Marlin 2.0 Support
Getting Marlin to run on the Monoprice Mini/Malyan M200.
Sound really interresting. Which branch should I compile for the mini delta ? What is supposed to work/not work ? USB ? SDCARD ? LCD ? EPROM ? WIFI ?
If you are running on the delta, I would expect mcheah's m4mpd port to be better. USB, SD, LCD should all work, but it's been quite a while since I've compiled it, since I needed a break.
Thank you so much. So i just flash the system using standard USB connector on the board?
You use the same method as any other firmware update - put the firmware on the SD card as update.bin (v1) or firmware.bin (v2) with a file named fcupdate.flg.
