Several behavioral neuroscience paradigms require measurements of consumption of liquids in the homecage, i.e. sucrose preference task, oral self-administration. Here, we present a low-cost, two-sipper apparatus that mounts on the inside of a standard mouse cage. Interactions are detected using photointerrupters at the base of each sipper which are logged to an SD card using a standard Arduino. Sippers are constructed from 15 mL conical tubes which allows additional volumetric measurements, the rest of the holding apparatus is 3D printed, and the apparatus is constructed with parts from Arduino and Sparkfun.
Meaghan Creed
Ricardo Lima Caratti
Open Technology
Georgi Angelov
