1Prototype
First, you need to design your glasses : which shape, what colors ? You also need to know where to fix your components on your glasses
2Components
After you have your design, you need to look for which components you need. You'll need an Arduino, wires, a power bank and buzzers
3Research
Once you have everything you need, you'll have to look for programs and adapt them for your need if necessary. You'll also have to look for circuit
4Assemble
After all the 3rd step is done, you can assemble everything
5Test
Finally you'll have to test if all of this works, if not then there's a problem you've got to solve !
