Nearly complete!
05/15/2018 at 17:48 • 0 commentsI just have to add the SnR figures, and waterfall images to compare the device with and without the shield. Those will happen in the next day or so. Thanks all!
Tool and Flux selection notes
05/15/2018 at 17:16 • 0 commentsI used no-clean liquid flux for this build instead of the usual rosin flux, as it's way way easier to clean off of a board with small components, or extra small spaces it can collect in.
You will also want to find a light clamp to hold the shield down until you tack a couple of the corners.
Jay Phantom
