I wanted to try and make my own Shotgun mic, so i started experimenting with electret capsules and preamp circuits. But no electronic project is concluded without a proper enclosure.
So in this project i'm building my own Mic Body, with an electret capsule and a phantom powered preamp.
If the quality of the end product is acceptable, i'm building another two or three, in longer versions to make them more directional.
At 3V. Curious thing, the modded capsule is less sensitive than the original one, also it picked alot of line noise (50hz), might be a shaving acting as an antenna or something.
