Repairing HoverChair
At the CRI, we are trying to rebuild a rolling chair with a hoverboard, from a previous project.
For our project, we choose to « rebuild » the Hover-Chair created by Franck Porteous, Louise Jacquot, Clément Caporal and Nicolas Larrouy.
The price of a wheel electrical hover chair is expensive, so we try to help people moving thanks to a cheap wheelchair, using Hover-Board and Arduino technology, which will cost a thousand less than a standard wheelchair.
To make the Hover-board work with a joystick we need to connect the hover-board with an Arduino card. So coding the Arduino card will allow a motor to move in the response of the joystick.
We also need to repair the chair of the Hover-chair because it is broken.
We have an overboard that didn’t work because the precedent group open it and modified it. Unfortunately, they didn’t manage to make the hover work but all the part of the Hoverchair were working separately.
So this is the inside of our overboard. We open it and unplug the wires and try to understand what is going on.
We buy a new Arduino card, a new battery and a new joystick. We also want to repair the chair who does not look great.
Téa
JPEG Image - 2.59 MB - 05/24/2018 at 09:38
Preview
JPEG Image - 3.98 MB - 05/24/2018 at 09:38
Preview
JPEG Image - 2.90 MB - 05/24/2018 at 09:38
Preview
  • Thursday , May 31st
    Joseph06/05/2018 at 18:25 0 comments
    The goal of this session was to first find a power supply of 26V (max voltage for the ESCs , but 40V for the motors). We took a generator and looked if it worked well with a multimeter. And it worked corectly. We also removed the motherboard of the Hoverboard, just so it was clearer with all those wires. We can put it bag at any moment
    We had to create plug so we could attach our ESCs to the generator. We created a plug with solder and heatshrink.  We then pluged it the escs to our generator as we planned to. Everything was going well.
    The motors beeped, the same beep to say they were receiveng juice but no signal. So this time we tried to give ESCs signal with arduino.
    We thirst tried the default code Servo Sweep and pluged the arduin to signal and turned on the power supply, now a different beep. But still no rotayion or anything, and this continuiss beep.
    We tried different codes, one specifically for ESCs. But still and always nothing. We aybe need to find a another way to send signal to these ESCs .
  • Thursday May, 23rd
    Joseph06/05/2018 at 18:12 0 comments
    We attached the two ESCs to each motor with the 3 wires. And we attached the two power enter of both ESCs together by soldering.
    We then plugged the power entry to the big blue battery. Both motors did that little noise to tell us that they werent receiving signal. SO we supposed that everything was ok.
    Now the goal was to send signal. We thought that it could do it with an arduino but we thirst tried with a remote control. We found a reciever and the remote, plugged the reciever to the signal wires of the ESC but nothing happend. We tried many times but still nothing.
    We ended the sesscion by thinking that the problem was actually that this fat blue baterry was dead. So we removed it.
  • Thursday 17th April
    Joseph05/24/2018 at 08:56 0 comments
    Last week, we unplugged the wires who were connected to the Arduino card and to the hover chair.
    This Arduino card was coding to allow the motor of  th HoverChair to move in response of the joystick but unfortunately it doesn’t work, because of the complications , and the motor.
    So we solved directly the ESC on the motor of the HoverBoard. Since it this a 3 phased motor, we didn't need to think about wich of the 3 wires of the esc goes on wich wire of the motor.
    The ESC has 3 differrent types of wire : 3 for the signal , but we will use only to of them, 3 for the motor that we solved last week, and 2 for power.
    Nicolas started repairing the chair by sawing some parts of this chair made out of tube, mesuring the height of the hoverboard to fix the wheels
View all 3 project logs
