DESIGN_hard_soft-smart_motor_driver-1.0.0.zip
This are the pcb designs in EAGLE, schematic, gerber files for pcb fabrication and also all the firmware developed in MPLAB XC8. Also a 3D model is included and a file with its register map for controlling via I2C. Same files as in GitHub link.
x-zip-compressed -
12.45 MB -
10/01/2018 at 18:18
Download
Arduino_Library-Smart-Motor-Driver-1.0.1.zip
This is an Arduino Library designed to interface with SAMI easily. Examples included, same as in GitHub link.
x-zip-compressed -
12.57 kB -
10/01/2018 at 18:13
Download
I2C Memory Map.xlsx
In this excel file I show you all required register to interact with SAMI directly. Also control modes are explained on sheet 2 of this document. In the details section you can find this info as an image for easy viewing.
sheet -
24.95 kB -
09/09/2018 at 18:43
Download
BOM_Digikey.csv
Bill of Material from Digikey, this corresponds for the second revision that uses 12F1840 instead of 12F1822. For more details go to the materials section.
ms-excel -
1.05 kB -
06/26/2018 at 01:02
Download
smart_motor_controller.pdf
Schematic of the SAMI board in pdf format. For PCB files get it on EAGLE from the Github repository. Gerbers also included.
Adobe Portable Document Format -
15.70 kB -
06/01/2018 at 17:29
Preview
