Firmware is done, is simple but effective
08/13/2018 at 21:44 • 0 commentsKeyboard have 4 layouts switchable with FN button.
- lowercase letters
- uppercase letters
- CTRL + lowercase letter
- CAPS LOCK
of course tweaking is unlimited, you can make own layouts
LAYOUT LEDs Letters 1 - lowercase A - OFF
FN - OFFESC, numbers, arrows, Backspace 2- uppercase A - ON
FN - OFFTAB, symbols, Delete
Arrows:
UP - Page UP
DOWN - Page Down
LEFT - Home
RIGHT - End
After any button press go back to Layout 13- CTRL A - OFF
FN - ONLetter = CTRL + Letter
Numbers = F1 to F10
Return = SHIFT + Return
After any button press go back to Layout 14- CAPS LOCK A - ON
FN - ONSame as mode 2
After any button press stay in Layout 4#include <Keypad.h> #include "Keyboard.h" const byte ROWS = 7; //four rows const byte COLS = 8; //four columns byte rowPins[ROWS] = {15, 18, 16, 19, 28, 31, 30}; //connect to the row pinouts of the keypad byte colPins[COLS] = {3, 4, 5, 6, 7, 8, 9, 14}; //connect to the column pinouts of the keypad //define the cymbols on the buttons of the keypads char directKeys[ROWS][COLS] = { {'`', '1', '2', '3', '4', '5', '6', 1}, {KEY_ESC, 'q', 'w', 'e', 'r', 't', 'y', ';'}, {'[', 'a', 's', 'd', 'f', 'g', 'h', 39}, //39 is ' {']', 'z', 'x', 'c', 'v', 'b', 'n', '-'}, {'7', '8', '9', '0', KEY_DOWN_ARROW, KEY_RIGHT_ARROW, KEY_LEFT_ARROW, KEY_UP_ARROW}, {'u', 'i', 'o', 'p', '.', '/', ' ', '='}, {'j', 'k', 'l', KEY_BACKSPACE, 'm', 92, KEY_RETURN, ','} }; char shiftKeys[ROWS][COLS] = { {'~', '!', '@', '#', '$', '%', '^', 1}, {KEY_TAB, 'Q', 'W', 'E', 'R', 'T', 'Y', ';'}, {'{', 'A', 'S', 'D', 'F', 'G', 'H', 34}, //34 is " {'}', 'Z', 'X', 'C', 'V', 'B', 'N', '_'}, {'&', '*', '(', ')', KEY_PAGE_DOWN, KEY_END, KEY_HOME, KEY_PAGE_UP}, {'U', 'I', 'O', 'P', '>', '?', ' ', '+'}, {'J', 'K', 'L', KEY_DELETE, 'M', 92, KEY_RETURN, ','} }; char fnKeys[ROWS][COLS] = { {'`', KEY_F1, KEY_F2, KEY_F3, KEY_F4, KEY_F5, KEY_F6, 1}, {KEY_ESC, 'q', 'w', 'e', 'r', 't', 'y', ';'}, {'[', 'a', 's', 'd', 'f', 'g', 'h', 39}, //39 is ' {']', 'z', 'x', 'c', 'v', 'b', 'n', '-'}, {KEY_F7, KEY_F8, KEY_F9, KEY_F10, KEY_DOWN_ARROW, KEY_RIGHT_ARROW, KEY_LEFT_ARROW, KEY_UP_ARROW}, {'u', 'i', 'o', 'p', '.', '/', ' ', '='}, {'j', 'k', 'l', KEY_BACKSPACE, 'm', 92, KEY_RETURN, ','} }; char capsKeys[ROWS][COLS] = { {'`', '1', '2', '3', '4', '5', '6', 1}, {KEY_ESC, 'Q', 'W', 'E', 'R', 'T', 'Y', ';'}, {'[', 'A', 'S', 'D', 'F', 'G', 'H', 39}, //39 is ' {']', 'Z', 'X', 'C', 'V', 'B', 'N', '-'}, {'7', '8', '9', '0', KEY_DOWN_ARROW, KEY_RIGHT_ARROW, KEY_LEFT_ARROW, KEY_UP_ARROW}, {'U', 'I', 'O', 'P', '.', '/', ' ', '='}, {'J', 'K', 'L', KEY_BACKSPACE, 'M', 92, KEY_INSERT, ','} }; // Create 3 new key layouts Keypad directLayout( makeKeymap(directKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) ); Keypad shiftLayout( makeKeymap(shiftKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) ); Keypad fnLayout( makeKeymap(fnKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) ); Keypad capsLayout( makeKeymap(capsKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) ); byte Layout = 0; char Key = 0; #define ledaA 27 #define ledFn 17 void setup() { Keyboard.begin(); pinMode(ledaA, OUTPUT); pinMode(ledFn, OUTPUT); digitalWrite(ledaA, LOW); digitalWrite(ledFn, LOW); directLayout.begin( makeKeymap(directKeys) ); shiftLayout.begin( makeKeymap(shiftKeys) ); fnLayout.begin( makeKeymap(fnKeys) ); capsLayout.begin( makeKeymap(capsKeys) ); } void loop() { switch (Layout) { case 0: digitalWrite(ledaA, LOW); digitalWrite(ledFn, LOW); Key = directLayout.getKey(); break; case 1: digitalWrite(ledaA, HIGH); digitalWrite(ledFn, LOW); Key = shiftLayout.getKey(); if (Key >= 2) { Layout = 0; } break; case 2: digitalWrite(ledaA, LOW); digitalWrite(ledFn, HIGH); Key = fnLayout.getKey(); if (Key >= 2) { Layout = 0; // } if (Key == KEY_RETURN) { Keyboard.press(KEY_LEFT_SHIFT); } if ((Key >= 'a') && (Key <= 'z')) { Keyboard.press(KEY_LEFT_CTRL); } break; case 3: digitalWrite(ledaA, HIGH); digitalWrite(ledFn, HIGH); Key = capsLayout.getKey(); break; default: Layout = 0; break; } if (Key == 1) { Layout++; Key = 0; delay(300); // if (Key) { // Keyboard.press(ctrlKey); Keyboard.press(Key); delay(100); Keyboard.releaseAll(); } }
firmware is unbelievable simple
06/19/2018 at 18:51 • 4 commentsHalf of firmware working, I need write Shift / FN support. , is incredibly simple.
I regret that I used such a powerful processor.
Sketch uses 11808 bytes (4%) of program storage space. Maximum is 253952 bytes.
#include <Keypad.h> #include "Keyboard.h" const byte ROWS = 7; //four rows const byte COLS = 8; //four columns char Keys[ROWS][COLS] = { {'`','1','2','3','4','5','6','X'}, {KEY_ESC,'q','w','e','r','t','y',';'}, {'[','a','s','d','f','g','h','*'}, {']','z','x','c','v','b','n','-'}, {'7','8','9','0',KEY_DOWN_ARROW,KEY_RIGHT_ARROW,KEY_LEFT_ARROW,KEY_UP_ARROW}, {'u','i','o','p','.','/',' ','='}, {'j','k','l',KEY_BACKSPACE,'m',92,KEY_RETURN,','} }; byte rowPins[ROWS] = {15, 18, 16, 19,28,31,30}; byte colPins[COLS] = {3, 4, 5, 6,7,8,9,14}; Keypad customKeypad = Keypad( makeKeymap(Keys), rowPins, colPins, ROWS, COLS); void setup(){ Keyboard.begin(); } void loop(){ char customKey = customKeypad.getKey(); if (customKey){ Keyboard.press(customKey); delay(100); Keyboard.releaseAll(); } }
First quick preview​
06/18/2018 at 11:37 • 3 commentsYou can adjust button height with spacers between boards. Of course you can use any button sizes an colors,
this button height is hard explainable (etc. my distributor have only this height with 1N switch force) but on real device is very interesting, of course in any height nobody can say that keyboard is comfortable. but 1N force version is very soft and easy to press.One bad is, every color have different switching force.
Please understand this is only technology preview no new fashion line and all keyboard is only for short writing.
Boards in fab ...
05/23/2018 at 21:19 • 0 commentsI am just ordered boards ... blue soldermask, in future all colors :D
Front board
05/22/2018 at 08:05 • 2 comments -
new layout
05/21/2018 at 08:28 • 0 comments -
Keyboard 56 buttons
05/21/2018 at 06:52 • 0 commentsbetter layout more buttons and always in good dimensions :)
7.4874 sq in (3.9150in x 1.9125in) / 4830.57 sq/mm (99.44mm x 48.58mm)
LCD ...
05/20/2018 at 20:28 • 0 commentsI started new project based on this keyboard
2 constructions possibilities
05/19/2018 at 20:55 • 0 comments- 2 layers bottom with buttons and top layer with nice silk (exactly like old Russians guys)
(effective use 10x10cm cm PCB order 1. half layer buttons an logic + 2. half layer front panel)- buttons only and silkscreen .... more hardcore look
Keyboard is ergonomic ... :)
05/18/2018 at 21:26 • 0 commentsRussian engineers it solve years ago when make clone of ZX spectrum
