Just got 10 new nrf24l01 modules from china. Now accepting bets whether these will work at all.
From a quick view (according to nordic's reference schematics, p. 69) - they are missing L1, L2, C3, C4, C6, R1, R2 and one of C8 or C9.
A project log for rf24boot: The NRF24L01 bootloader
nrf24l01 over-the-air bootloader for different microcontrollers
I got some of these, at $4 for 10pcs so worth grabbing a few to test. But from my testing they are not wirelessly compatible with the nRF24L01+ modules. The seller did give me some code (SDK) that looks to be the code running on the module.
Yep, they have that NO_ACK bit flipped. So the only way to use them with geniuine stuff - forget about AUTO_ACK,
I disable AA and check that most of the other registers where the correct.
Anyway here is the code I was sent by the vendor, I found the UART part interesting as if this chip had a serial port running at 115200 like the code suggests that could be useful.
http://sz.ctfs.ftn.qq.com/ftn_handler/ad2ac54fdb946bbb3ae3fef427f2fc6ea9907ee63d07ba4233dd6a5d08c8db5f77c57c65b29134f21b15c70ed939efcb1767ccba6a8da427a92d427214628dfb/?fname=%E7%92%90%E5%AF%B8%E5%A2%96%E9%90%A9%E5%AD%98%E5%BD%83NRF.rar&k=7c306237dd149a9c99...
Yeah, I've seen that. They're using an nrf24l01 connected to that STC 8051 MCU that does have an UART.
If you want to deal with STCs - checkout stcdude at my github.
These were dirt cheap, some $8.61 for 10 of them incl. shipping ($2.25).
I found even cheaper once, their pcbs seem smaller - http://www.ebay.de/itm/10pcs-Wireless-Transceiver-Module-similar-to-NRF24L01-2-4G-wireless-module-M73-/301402793401?pt=LH_DefaultDomain_0&hash=item462d01a5b9
And these are 7,50 with free shipping! - http://www.ebay.de/itm/10pcs-2-4GHz-Wireless-Module-Power-enhanced-version-Compatible-NRF24L01-M73-/301402792434?pt=LH_DefaultDomain_0&hash=item462d01a1f2
Looking at the reference schematics and the missing components list - the modules have one of the differential amp outputs floating, so it likely has a 30-40% decrease in TX power. Not speaking of missing decoupling, that likely makes things even worse. Add a (most likely - rip-off asic that's less sensitive than original) we have a total 'winner'.
The one on your link with smaller PCB looks like they're lacking even more components. And unlike black ones you can't just solder them in.
What's bugging me is that mine are missing the IREF resistor, which CAN be a total problem. Will find out if it works in the evening.
Wow, you definitely know something about those modules :)
Well, I did take the effort to visit the analog electronics guru working on the next floor for some advice, so don't consider me an RF guru - I'm not. I'll be making a detailed writeup about this crap quite soon in my blog with schematics.
And yes, the modules kind of worked, like it did read some registers and did receive some data. But not the data I've sent to it. In fact - looks like I'm only receiving random gibberish with these modules.
So how much cheaper where they in comparison?
