1The basic building blocks
There will not be a step by step for ColorChord. All sections can be built using many styles and selection of whatever components desired.
The building blocks are the following.
1 - Audio oscillator. Three are required. I chose the 555 timer.
Each oscillator is adjusted to a chosen frequency that relates
to one of the three primary colors red, green or blue.
2 - Clock. I used a two transistor astable multi-vibrator running
between 10 and 20hz
3 - Five step FSM sequencer. I used the first, third and fifth outputs.
I choose DTL but 74xx TTL logic would save space.
4 - Audio amp. I used a scraped unit from a CD player.
