Oh no...
06/13/2018 at 20:56 • 0 commentsI have a disappointing update...I was doing a little size checking and then some research into pi Zero...a raspberry pi 3 will NOT fit into a DS Lite. I do not know enough about doing custom pin changes on the Pi Zero to make everything work using that (mostly audio). So I have decided to change this project from putting a Pi into a DS Lite to putting a Pi into a Original Gameboy case!
Audio Added
05/31/2018 at 16:23 • 0 commentsLast night I was able to solder on the little AMP chip and speaker. I tested it and it works! So far so good!
Powerboost soldering success
05/25/2018 at 15:47 • 0 commentsWell I was able to solder on the power switch and wires to go to the battery. Tested power from battery and tested that battery was charging and both worked!
Parts Arriving Today!
05/24/2018 at 23:04 • 0 commentsI should get the rest of my parts today for the project and then I can start building! Wish me luck. I don't want any Frankenstein disasters coming from my hands...
cloudious
