1Mount Camera to Cage Food/Water Hopper
Find a position on the food/water hopper where the Cage Cam can be mounted such that it has an unobstructed view of the cage bedding. The camera should be mounted so that the barrel of the lens is perpendicular to the cage floor.
When ready to mount, place the Cage Cam in the desired spot and place the rectangular mounting magnet on the other side of the hopper bars so that it mates with the Cage Cam enclosure magnets.
2Attach Power and Signal Wires
Route the signal cable from the Cage Cam to a particle photon that is connected to the MIOS ecosystem or to the corresponding expansion port on a MIOS Environmental Sensor.
Ensure the power cable is long enough to reach the cage from a standard 5V, 1A USB power supply.
Plug the USB side into the power supply and route the other side into the cage via the lid and plug it in to the Cage Cam.
3Monitor Cage Cam using the Blynk powered MIOS App!
