Arduino code
A project log for Dynamic Interactivity G2: UN_SDG
A group assignment to promote the United Nations Sustainable Development Goals with the use of digital fabrication and physical computing.
tan-yong-jieTan Yong Jie 08/29/2018 at 05:180 Comments
#include <Adafruit_NeoPixel.h>
#define trigPin01 12
#define echoPin01 13
#define trigPin02 10
#define echoPin02 11
#define trigPin03 8
#define echoPin03 9
#define trigPin04 6
#define echoPin04 7
#define trigPin05 4
#define echoPin05 5
#define vibrationPin06 3
#define vibrationPin07 2
unsigned char stateInterrupt1 = 0;  // pin 3
unsigned char stateInterrupt0 = 0;  // pin 2
#define LED01 A5
#define NUM_LED01 176
Adafruit_NeoPixel strip01 = Adafruit_NeoPixel(NUM_LED01, LED01, NEO_GRB + NEO_KHZ800);
void setup() {
  Serial.begin(9600);
  pinMode(trigPin01, OUTPUT);
  pinMode(echoPin01, INPUT);
  pinMode(LED01, OUTPUT);
  pinMode(trigPin02, OUTPUT);
  pinMode(echoPin02, INPUT);
  pinMode(trigPin03, OUTPUT);
  pinMode(echoPin03, INPUT);
  pinMode(trigPin04, OUTPUT);
  pinMode(echoPin04, INPUT);
  pinMode(trigPin05, OUTPUT);
  pinMode(echoPin05, INPUT);
  pinMode(vibrationPin06, INPUT);
  pinMode(vibrationPin07, INPUT);
  attachInterrupt(1, interrupt1, FALLING);
  attachInterrupt(0, interrupt0, FALLING);
  strip01.begin();
  strip01.show();
void loop() {
  byte incomingByte = '?';
  if (Serial.available() > 0) {
    incomingByte = Serial.read();
    Serial.println(incomingByte);
  switch (incomingByte) {
    case 62: //this should be equivalent to ASCII ">"
      turnAllRed();
      break;
    case 60: //this should be equivalent to ASCII "<"
      turnAllOff();
      break;
    case 43: //this should be equivalent to ASCII "+"
      break;
    case 49: //this should be equivalent to ASCII "1"
      LEDTurnGreen01();
      delay(500);
      while (checkVSensor06() == false) {
        delay(10); // Sensor is slow in returning response, so add a little delay
      break;
    case 50: //this should be equivalent to ASCII "2"
      LEDTurnGreen02();
      delay(500);
      while (checkVSensor07() == false) {
      break;
    case 51: //this should be equivalent to ASCII "3"
      LEDTurnGreen03();
      delay(500);
      while (checkSensor01() == false) {
      break;
    case 52: //this should be equivalent to ASCII "4"
      LEDTurnGreen04();
      delay(500);
      while (checkSensor02() == false) {
      break;
    case 53: //this should be equivalent to ASCII "5"
      LEDTurnGreen05();
      delay(500);
      while (checkSensor03() == false) {
      break;
    case 54: //this should be equivalent to ASCII "6"
      LEDTurnGreen06();
      delay(500);
      while (checkSensor04() == false) {
      break;
    case 55: //this should be equivalent to ASCII "7"
      LEDTurnGreen07();
      delay(500);
      while (checkSensor05() == false) {
      break;
void interrupt1() {
  stateInterrupt1++;
void interrupt0() {
  stateInterrupt0++;
boolean checkSensor01() {
  float duration01, distance01;
  digitalWrite(trigPin01, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin01, HIGH);
  delayMicroseconds(10);
  duration01 = pulseIn(echoPin01, HIGH, 1000000);
  distance01 = (duration01 / 2) * 0.0344;
  if (distance01 >= 40 ) {
    Serial.print('c');
    turnAllRed();
    return true;
  else {
    return false;
boolean checkSensor02() {
  float duration02, distance02;
  digitalWrite(trigPin02, LOW);
  digitalWrite(trigPin02, HIGH);
  duration02 = pulseIn(echoPin02, HIGH);
  distance02 = (duration02 / 2) * 0.0344;
  if (distance02 >= 40) {
    Serial.print('d');
    turnAllRed();
    return true;
  else {
    return false;
boolean checkSensor03() {
  float duration03, distance03;
  digitalWrite(trigPin03, LOW);
  digitalWrite(trigPin03, HIGH);
  duration03 = pulseIn(echoPin03, HIGH);
  distance03 = (duration03 / 2) * 0.0344;
  if (distance03 >= 40) {
    Serial.print('e');
    turnAllRed();
    return true;
  else {
    return false;
boolean checkSensor04() {
  float duration04, distance04;
  digitalWrite(trigPin04, LOW);
  digitalWrite(trigPin04, HIGH);
  duration04 = pulseIn(echoPin04, HIGH);
  distance04 = (duration04 / 2) * 0.0344;
  if (distance04 <= 90) {
    Serial.print('f');
    turnAllRed();
    return true;
  else {
    return false;
boolean checkSensor05() {
  float duration05, distance05;
  digitalWrite(trigPin05, LOW);
  digitalWrite(trigPin05, HIGH);
  duration05 = pulseIn(echoPin05, HIGH);
  distance05 = (duration05 / 2) * 0.0344;
  if (distance05 >= 40) {
    Serial.print('g');
    turnAllRed();
    return true;
  else {
    return false;
boolean checkVSensor06() {
  if (stateInterrupt1 != 0) {
    turnAllRed();
    Serial.print('a');
    return true;
    //    delay(500);
  else
    return false;
boolean checkVSensor07() {
  if (stateInterrupt0 != 0) {
    turnAllRed();
    Serial.print('b');
    return true;
    //    delay(500);
  else
    return false;
void LEDTurnGreen01() {
  for (int pixID = 0; pixID < 14; pixID++) {
    strip01.setPixelColor(pixID, 0, 255, 0);
    strip01.show();
void LEDTurnRed01() {
    strip01.setPixelColor(pixID, 255, 0, 0);
    strip01.show();
void LEDTurnOff01() {
    strip01.setPixelColor(pixID, 0, 0, 0);
    strip01.show();
void LEDTurnGreen02() {
  for (int pixID = 14; pixID < 38; pixID++) {
    strip01.show();
void LEDTurnRed02() {
    strip01.show();
void LEDTurnOff02() {
    strip01.show();
void LEDTurnGreen03() {
  for (int pixID = 38; pixID < 47; pixID++) {
    strip01.show();
void LEDTurnRed03() {
    strip01.show();
void LEDTurnOff03() {
    strip01.show();
void LEDTurnGreen04() {
  for (int pixID = 47; pixID < 55; pixID++) {
    strip01.show();
void LEDTurnRed04() {
    strip01.show();
void LEDTurnOff04() {
    strip01.show();
void LEDTurnGreen05() {
  for (int pixID = 55; pixID < 70; pixID++) {
    strip01.show();
void LEDTurnRed05() {
    strip01.setPixelColor(pixID, 150, 0, 0);
    strip01.show();
void LEDTurnOff05() {
    strip01.show();
void LEDTurnGreen06() {
  for (int pixID = 70; pixID < 113; pixID++) {
    strip01.show();
void LEDTurnRed06() {
    strip01.show();
void LEDTurnOff06() {
    strip01.show();
void LEDTurnGreen07() {
  for (int pixID = 114; pixID < 175; pixID++) {
    strip01.show();
void LEDTurnRed07() {
    strip01.show();
void LEDTurnOff07() {
    strip01.show();
void turnAllRed() {
  LEDTurnRed01();
  LEDTurnRed02();
  LEDTurnRed03();
  LEDTurnRed04();
  LEDTurnRed05();
  LEDTurnRed06();
  LEDTurnRed07();
void turnAllOff() {
  LEDTurnOff01();
  LEDTurnOff02();
  LEDTurnOff03();
  LEDTurnOff04();
  LEDTurnOff05();
  LEDTurnOff06();
  LEDTurnOff07();
