#include <Adafruit_NeoPixel.h>
#define trigPin01 12
#define echoPin01 13
#define trigPin02 10
#define echoPin02 11
#define trigPin03 8
#define echoPin03 9
#define trigPin04 6
#define echoPin04 7
#define trigPin05 4
#define echoPin05 5
#define vibrationPin06 3
#define vibrationPin07 2
unsigned char stateInterrupt1 = 0;
unsigned char stateInterrupt0 = 0;
#define LED01 A5
#define NUM_LED01 176
Adafruit_NeoPixel strip01 = Adafruit_NeoPixel(NUM_LED01, LED01, NEO_GRB + NEO_KHZ800);
void setup() {
Serial.begin(9600);
pinMode(trigPin01, OUTPUT);
pinMode(echoPin01, INPUT);
pinMode(LED01, OUTPUT);
pinMode(trigPin02, OUTPUT);
pinMode(echoPin02, INPUT);
pinMode(trigPin03, OUTPUT);
pinMode(echoPin03, INPUT);
pinMode(trigPin04, OUTPUT);
pinMode(echoPin04, INPUT);
pinMode(trigPin05, OUTPUT);
pinMode(echoPin05, INPUT);
pinMode(vibrationPin06, INPUT);
pinMode(vibrationPin07, INPUT);
attachInterrupt(1, interrupt1, FALLING);
attachInterrupt(0, interrupt0, FALLING);
strip01.begin();
strip01.show();
void loop() {
byte incomingByte = '?';
if (Serial.available() > 0) {
incomingByte = Serial.read();
Serial.println(incomingByte);
switch (incomingByte) {
case 62:
turnAllRed();
break;
case 60:
turnAllOff();
break;
case 43:
break;
case 49:
LEDTurnGreen01();
delay(500);
while (checkVSensor06() == false) {
delay(10);
break;
case 50:
LEDTurnGreen02();
delay(500);
while (checkVSensor07() == false) {
delay(10);
break;
case 51:
LEDTurnGreen03();
delay(500);
while (checkSensor01() == false) {
break;
case 52:
LEDTurnGreen04();
delay(500);
while (checkSensor02() == false) {
break;
case 53:
LEDTurnGreen05();
delay(500);
while (checkSensor03() == false) {
break;
case 54:
LEDTurnGreen06();
delay(500);
while (checkSensor04() == false) {
break;
case 55:
LEDTurnGreen07();
delay(500);
while (checkSensor05() == false) {
break;
void interrupt1() {
stateInterrupt1++;
void interrupt0() {
stateInterrupt0++;
boolean checkSensor01() {
float duration01, distance01;
digitalWrite(trigPin01, LOW);
delayMicroseconds(2);
digitalWrite(trigPin01, HIGH);
delayMicroseconds(10);
duration01 = pulseIn(echoPin01, HIGH, 1000000);
distance01 = (duration01 / 2) * 0.0344;
if (distance01 >= 40 ) {
Serial.print('c');
turnAllRed();
return true;
else {
return false;
boolean checkSensor02() {
float duration02, distance02;
digitalWrite(trigPin02, LOW);
digitalWrite(trigPin02, HIGH);
duration02 = pulseIn(echoPin02, HIGH);
distance02 = (duration02 / 2) * 0.0344;
if (distance02 >= 40) {
Serial.print('d');
turnAllRed();
return true;
else {
return false;
boolean checkSensor03() {
float duration03, distance03;
digitalWrite(trigPin03, LOW);
digitalWrite(trigPin03, HIGH);
duration03 = pulseIn(echoPin03, HIGH);
distance03 = (duration03 / 2) * 0.0344;
if (distance03 >= 40) {
Serial.print('e');
turnAllRed();
return true;
else {
return false;
boolean checkSensor04() {
float duration04, distance04;
digitalWrite(trigPin04, LOW);
digitalWrite(trigPin04, HIGH);
duration04 = pulseIn(echoPin04, HIGH);
distance04 = (duration04 / 2) * 0.0344;
if (distance04 <= 90) {
Serial.print('f');
turnAllRed();
return true;
else {
return false;
boolean checkSensor05() {
float duration05, distance05;
digitalWrite(trigPin05, LOW);
digitalWrite(trigPin05, HIGH);
duration05 = pulseIn(echoPin05, HIGH);
distance05 = (duration05 / 2) * 0.0344;
if (distance05 >= 40) {
Serial.print('g');
turnAllRed();
return true;
else {
return false;
boolean checkVSensor06() {
if (stateInterrupt1 != 0) {
turnAllRed();
Serial.print('a');
return true;
else
return false;
boolean checkVSensor07() {
if (stateInterrupt0 != 0) {
turnAllRed();
Serial.print('b');
return true;
else
return false;
void LEDTurnGreen01() {
for (int pixID = 0; pixID < 14; pixID++) {
strip01.setPixelColor(pixID, 0, 255, 0);
strip01.show();
void LEDTurnRed01() {
strip01.setPixelColor(pixID, 255, 0, 0);
strip01.show();
void LEDTurnOff01() {
strip01.setPixelColor(pixID, 0, 0, 0);
strip01.show();
void LEDTurnGreen02() {
for (int pixID = 14; pixID < 38; pixID++) {
strip01.show();
void LEDTurnRed02() {
strip01.show();
void LEDTurnOff02() {
strip01.show();
void LEDTurnGreen03() {
for (int pixID = 38; pixID < 47; pixID++) {
strip01.show();
void LEDTurnRed03() {
strip01.show();
void LEDTurnOff03() {
strip01.show();
void LEDTurnGreen04() {
for (int pixID = 47; pixID < 55; pixID++) {
strip01.show();
void LEDTurnRed04() {
strip01.show();
void LEDTurnOff04() {
strip01.show();
void LEDTurnGreen05() {
for (int pixID = 55; pixID < 70; pixID++) {
strip01.show();
void LEDTurnRed05() {
strip01.setPixelColor(pixID, 150, 0, 0);
strip01.show();
void LEDTurnOff05() {
strip01.show();
void LEDTurnGreen06() {
for (int pixID = 70; pixID < 113; pixID++) {
strip01.show();
void LEDTurnRed06() {
strip01.show();
void LEDTurnOff06() {
strip01.show();
void LEDTurnGreen07() {
for (int pixID = 114; pixID < 175; pixID++) {
strip01.show();
void LEDTurnRed07() {
strip01.show();
void LEDTurnOff07() {
strip01.show();
void turnAllRed() {
LEDTurnRed01();
LEDTurnRed02();
LEDTurnRed03();
LEDTurnRed04();
LEDTurnRed05();
LEDTurnRed06();
LEDTurnRed07();
void turnAllOff() {
LEDTurnOff01();
LEDTurnOff02();
LEDTurnOff03();
LEDTurnOff04();
LEDTurnOff05();
LEDTurnOff06();
LEDTurnOff07();
