1Getting all the components
Get all the components mentioned
2Generating Electricity
I made a acrylic base for Piezo to stick on it and make sure to drill holes below every Piezo else it won't generate electricity because Piezo need tension and compression to generate electricity. And place piece of foam or some same type of material.
Connect all Piezo elements together in parallel.(as circuit diagram)
Rectifier is converting AC current into DC current.
3Auto Lacing
Used drill machine or dremel to make holes in the shoe. And zip ties to direct the laces towards the servo.
You can use different things to direct the laces but I couldn't find anything then the zip tie. I used servo knob code you can also use different code to control servo. You need to know the basics to code Arduino Pro Mini or Google it .
4Step Counting
I used the tally counter to count steps.When you open this type of tally counter you can attach two wire to the count button's two terminal and attach a push button (But this was only by one shoe). So you will require this app I made to enter the number on counter and your weight .And the app will count average cal burned ,distance (in km) and obviously the steps.
5Adding Some Led's
Here I added 3 led's in parallel with a switch and used the power bank to power it.
