Make Battery Tester
This simple device allows you to measure the capacity of an accumulator or rechargeable battery (measured in mAh / Ah) and discharge energy
I found this circuit on internet with only schematic.I make PCB by eagle software and order PCB online from JLCPCB.COM. You can try make PCB online by upload to JLCPCB.COM with only 2$ for 10PCB with high quality. my project works great, you can see the result on my video. The gerber file, code,schematic, video on my youtube channel i will upload below.Please check
Thank you for watch
youkito1991 wrote 05/30/2018 at 13:34 point
If you have any problem, please comment here i will help you
