We have as parts:
- Adafruit HUZZAH with ESP8266 as MC
- HX711 breakout as load cell amplifier and ADC
- two resistors (2x 4.7 kΩ) for the sensors (DHTxx and DS18B20)
- two resistors (1 MΩ, 220 kΩ) as voltage divider to measure the battery drain * [an additional capacitor in parallel to the lower resistor is recommended but not prepared on the PCB yet]
- screw terminals
- for the PCB we need also a CN3065 breakout, this is the solar charging IC (not provided in the bread board version)
- custom PCB
Onur Şurgun
Umut Çağrı MANGALTEPE
makeTVee
Adam Lučanský
