1SolarUPS V3 versions
You can choose from these versions:
2Mechanical drawings
V3 SLA fixing points:
V3 Li fixing points:
V3 PCB fixing points & dimensions:
3Wiring Solar Input & DC output
This way you can connect the cables:
Ttake care of the correct polarity!
4Wiring Battery
This way you can connect the battery (SLA & Li):
Gabor Futo
