It lives to fight another day!
06/07/2018 at 09:52 • 0 commentsThere, fixed it. Milled out the burnt pcb area with a dremel and a tiny drill bit (0.8 mm). Made sure not to leave any black area on the pcb, basically creating an "air gap". Then filled it with epoxy.
A zombie food mixer
06/07/2018 at 09:50 • 0 commentsThis was the state of the mixer before fixing the pcb - a zombie. Not dead and unresponsive, yet seemed to have a life of its own:
When plugged in the engine starts working, even though the main switch is in the "Off" position, you can see the arcing towards the end of the video.
