Uploaded some images of the test circuit I built. The rachet system is being redesigned and in later versions the generator will be able to generate power while moving in both directions. This design change involves swapping the ratchet system for a rack and pinion system that will rotate the generator clockwise even no matter which way the rack and pinion is moving.
