Below you can find a more in depth description of how this project works (this is still being updated)
This project is at it's simplist a generator however the way that this generator is desgined to mount and the source that is used to generate the electricity is different than conventional generators.
This generator uses the motion of a person as they go about their normal day to generate electricity and stores that electricity in a capacitor for later use. The design uses a racheting system so that power is only generated when moving one way, because of this desing choice no AC to DC rectifier circuit is required simplyfying the design and negating conversion losses.
