Cheap-ass microphones in the Ruben's tube
08/07/2018 at 19:33 • 0 commentsSo i finally got around to test the rubens tube more. What I did this time, was noting where are the peaks and the bottoms of the waves when a 400hz is played into the tube. Then I mounted cheap-ass microphones from ebay into three of the positions. Played the 400hz signal into the tube again and inspected the microphone output on an oscilloscope. I was very glad to find out that a clear difference between these points could measured! This measn that I should be able to digitize the tube.
Building traditional Ruben's tube
06/17/2018 at 12:17 • 0 commentsAssembly
So I finally got my Ruben's tube working. As there are many instructions online, I will not go into many details. Basic steps I took:
- Drill 96 holes each 2mm in diameter and 20mm distance apart alongside the top of the pipe.
- Weld one side of the steel pipe shut.
- Weld two small steel pipes, 10mm in diameter and approximately 50mm in length, into the steel pipe for connecting the gas tubes.
- Sealed the other end of the steel tube with a surgical glove and duct tape forming a rubber membrane.
- Connected grill gas supply to the steel pipe by splitting one gas tube coming from the pressure adapter into two and connecting each of them to the small welded-in pipes.
- Placed a Bluetooth speaker in front of the membrane.
Tube in action
Getting the parts
06/12/2018 at 17:32 • 0 commentsParts
First I did some shopping and basic preparation. I got myself:
- 2000mm length, 76mm diameter steel tube.
- 5000mm length of gas tube.
- Regular grill gas.
- Gas valve pressure adapter.
- Couple of fittings for connecting gas tube to the pipe.
- A steel plate for sealing off one end of the steel pipe.
- A t-connector for splitting the gas tube into two.
