Attention Please
07/03/2018 at 14:02 • 0 comments -
Build Complete
06/22/2018 at 02:22 • 3 commentsThe printed circuit boards I designed for my video card arrived in the mail today, and I got it put together.
It works great. The amount of noise in the video signal is vastly reduced, and I no longer have any glitches during memory transfers. With the board, I have been able to successfully run the Bold MSX demo on my RC2014 with Graphics and Sound, 100% glitch free.
MSX Demos on Homebrew Hardware
06/20/2018 at 01:35 • 0 commentsI've been able to successfully run the Bold demo for the MSX 1 on the RC2014 with my TMS9918A video card.
Since I have mapped the TMS9918A's RAM and register ports to 98 and 99, the same as on the MSX, the demo will output video 100% unmodified. Unfortunately there is no audio in the unmodified code because the YM2149 sound card for the RC2014 does not support the port configuration used by the MSX. With a minor modification, however, It's possible to get sound working.
Rather than trying to get MSX-DOS to run on the RC2014, which would be a much bigger undertaking, I used my z80ctrl board to load the demo binaries directly from the SD card into memory at origin 100H. The demoa.com and demob.com files were extracted from the bold.dsk image using openMSX with the following console commands:
virtual_drive bold.dsk diskmanipulator export virtual_drive .
One tiny modification was made to demoa.com: I poked a HALT (76) at address 152 in place of the RET that was there before. This is necessary because there's no other software to return to, so I needed to halt the processor when this part was done so I could load the next part of the demo. demob.com was completely unmodified, and was simply loaded at 100H and run after demoa.com halted.
To get sound working, I needed to modify the routine in demob.com that sends audio commands to the YM2149. The unmodified version looks like this:
06fa 0e a0 .. LD C,A0H 06fc 21 f9 07 !.. LD HL,07F9H 06ff ed 79 .y OUT (C),A 0701 0c . INC C 0702 ed a3 .. OUTI 0704 0d . DEC C 0705 3c < INC A 0706 fe 0d .. CP 0DH 0708 20 f5 . JR NZ,-11 070a ed 79 .y OUT (C),A 070c 7e ~ LD A,(HL) 070d a7 . AND A 070e f8 . RET M 070f 0c . INC C 0710 ed 79 .y OUT (C),A 0712 c9 . RETPort A0H is the address port, and A1H is the data port used by the MSX for the YM2149. The demo loads A0H into register c, then uses the out (c), a and outi commands to send data to the chip at the port address stored in c. It switches c back and forth between A0H and A1H using the inc and dec instructions. I had to be careful about modifying the code because any change to the length of the instructions would change the offsets of the rest of the program and cause absolute references to those addresses to become invalid.
I had initially devised a much more complicated scheme but thanks to neon reminding me that "out (c), a" is a 2 byte instruction, the same as "out (nn), a", I was able to simply replace the "out (c), a" instructions with "out (nn), a" instructions that send data directly to the desired port. I still had to load c with the data port address to use the outi instruction, but I no longer needed to switch c back and forth between ports, so I changed the inc c/dec c instructions to nops. The modified version of the code that uses the default D0/D8 ports for the RC2014 YM/AY sound card looks like this:
06fa 0e d0 .. LD C,D0H 06fc 21 f9 07 !.. LD HL,07F9H 06ff d3 d8 .. OUT (D8H),A 0701 00 . NOP 0702 ed a3 .. OUTI 0704 00 . NOP 0705 3c < INC A 0706 fe 0d .. CP 0DH 0708 20 f5 . JR NZ,-11 070a d3 d8 .. OUT (D8H),A 070c 7e ~ LD A,(HL) 070d a7 . AND A 070e f8 . RET M 070f 00 . NOP 0710 d3 d0 .. OUT (D0H),A 0712 c9 . RET
I used z80ctrl's scripting facility to load both parts of the demo into memory and then automatically patch and run them. With this script, it's possible to run the unmodified demo binaries simply by typing "do bold" (assuming the script has been saved in a file called bold and copied to the z80ctrl's SD card along with both demoa.com and demob.com).
page 20 clkdiv 4 loadbin 100 demoa.com poke 152 76 run 100 loadbin 100 demob.com poke 06fb d0 poke 06ff d3 poke 0700 d8 poke 0701 00 poke 0704 00 poke 070a d3 poke 070b d8 poke 070f 00 poke 0710 d3 poke 0711 d0 run 100
First, the script selects page 20 (the start of RAM) on the 512KB RAM/ROM board I am using. Next, it sets the clock divider to 4, because the full 10MHz clock is too fast for the TMS9918A and results in video glitches when the memory writes that the TMS9918A is still processing are overrun by subsequent writes sent by the Z80. Now it loads the first demo binary into memory at origin 100H. It pokes 76H into address 152H to change the RET instruction to a HALT, then it runs the first binary. When this finishes, it loads the second binary and pokes the changes for the sound ports into the appropriate locations in memory. When that's finished, it runs the demo.
Update: I have posted a pre-patched version of Bold in the downloads that includes scripts to run it either on z80ctrl or CP/M.
J.B. Langston
