Since the limiting factor for the size of the blades is the size of your 3D printer's print bed, I designed this parametrically as well.
It supports these parameters:
- Blade diameter (from tip to tip)
- Blade height
- Shaft diameter
- Thickness of the blade.
As our savonious design requires three of these, I figured it would be smart to design it such that
