Academic research has shown that a Savonious windmill design with: 2:1 aspect (height:width); 10% blade overlap; and a stack of 3 sets of half-cylinder blades offset by 120 degrees is within a few percent of the efficiency of more exotic shapes for Savonious windmills that would require 3D printing of the entire blade structure. Recycled round containers are an easy source of cylindrical material for the blades. 3D printing structures for the ends of the blades makes for easy assembly, but does limit the diameter of the windmill. This design allows for easy scaling of the windmill to match the requirements of various projects.
Greg
The initial stator design, "Rev C", PCB has arrived from OSHPark. I need to test the performance of this design so I have an order of magnitude guess on what the design parameters should be for the next version.
Kostas Lagogiannis
Roger
Ric Real
