Inside a closed loop, radiant heat will increase water pressure that drives the turbine faster and faster. As turbine speed is increased, it receives torque multiplication from its 2.5:1 pulley drive. When the turbine drives the generator, it does so faster and with less effort from the turbine as opposed to a direct drive.
Scott
Josh Starnes
Soham Chakraborty
