Slide the Y belt holder part and his nut on the front frame. x1 Y belt holder printed part x1 screw M3x20mm x1 nut M3x2mm x1 screw M6x12mm x1 coller nut M6
Set one motor on the Y beld holder printed part and slide the assemblage on the rear frame. x1 Motor x2 screws M3x12mm x1 screw M6x12mm x1 coller nut M6
2
Built the four feet of the Veletiskárna.
Assemble the four feet. x4 Corner printed part x4 Rubber feet x8 coller nuts M6 x8 screws M6x12mm x4 coller nuts M5 x4 screws M5x20mm
Don't make the mistake!
3
Slide the Y printed bearings.
Use sandpaper and lubricating grease. x2 Y printed bearings x1 lubricating grease pot
The bearings have to slice very easily.
Then slice x3 M6 coller nuts at the oposite chanel from the bearings and x2 M6 coller nuts on the top. Like the picture.
Now you can assemble the feet.
4
Assemble the feet - So all the square bottom frame.
Here is what we aim.
x4 builted feet
Be careful to NOT have the printed part like this ▼
Then set theses pieces ▼ x8 screws M6x12mm x4 coller nuts M6 (four are already in the frame if you well follow the
5
Build the upper frames.
We need... x2 metal corner x10 screws M6x12mm x4 coller nuts M6 (six are already setted if you well follow the previous instructions)
The sens has to NOT be the same.
You can still set the exacte position off the upper frame later.
Now you have to put nuts in channels. x6 coller nuts M6
6
Built the X axe driver parts.
You also have to use sandpaper and greace for the parts going in the frame.
Motor side x1 Motor holder for X axe printed part x1 Motor x3 screws M3x8mm x1 Motor to belt (pulley)
Between the printed parts x1 Nozzle holder printed part x1 Belt x2 Rods
On both printed parts x2 screws rod cap x8 screws M3x16mm x8 nuts M3x2mm
Opposite side x1 Belt holder for X axe printed part x1 Pulley x1 nuts M3x2mm x1 screw M3x20mm
7
Set the X and Z axes drivers parts.
1. Set the Z axe motors. x2 Motors x2 Screw rods x2 Motor to srew rod parts x2 Z axe motor holder printed parts x2 screws M6x12mm (their nuts are already in position in frames) x8 screws M3x8mm
2. Slide the Assemblage of X axe driver parts. x1 Assemblage of X axe driver parts
3. Set the Top of screw rod printed parts. x2 Top of screw rod printed parts x4 screws M6x12mm x4 coller nuts M6
8
Build the bed and assemble it.
x1 big metal plate x2 small metal plate x2 big angle plate printed parts x2 small angle plate printed parts x1 Belt to bed printed part x2 small bed to bearing parts x2 big bed to bearing parts x20 screws M5x12mm x20 stop nuts M5 x8 washer M5 x4 screws M3x30mm x8 washer M3 x4 stop nuts M3 x4 screws M3x25mm x4 nuts M3x2mm
9
Install the belt.
x1 Belt x1 Belt tensionner printed part x1 screw M3x35mm x1 nut M3x2mm
