version 1 Bacteria Algae reactor 156 shapes.stl
all 24 cells together for oxygen co2 resperation, cells piped to resevoir and small pump in those resevoirs. white is bacteria load and green is algae load
Standard Tesselated Geometry -
7.30 MB -
07/14/2018 at 16:05
Download
U tube.stl
This is the U shaped salt bridge, I printed at low quality but may not be water proof, for best results print this peice on your finest settings with no supports, add a brim.
25.08 kB -
07/11/2018 at 13:53
Download
1st try bio reactor.stl
no supports, print upright.
2.23 kB -
07/11/2018 at 13:53
Download
hollow electrode bioreactor.stl
A hollowed out version of the electrode tube so it will print faster and use less filament.
18.73 kB -
07/11/2018 at 13:53
Download
electrode tube bioreactor.stl
solid with infil tube, easier to waterproof ,but uses more print time and filament.
13.17 kB -
07/11/2018 at 13:53
Download
