Update project log
07/26/2018 at 15:48 • 0 commentsAdded Sensor detection on boot
Added smoke sensor MQ2 - Tests ppm and checks air quality while reading temperatures
Updated Intro screen to include mode, smoke MQ2, Alarm state.
typical dump from board
Smoke Sensor Installed
Smoke Sensor Reading :343
Concentration of gas
LPG: 522 ppm
CO: 17465 ppm
Smoke: 1917 ppm
00Reading Mode type :0
Storing Mode type :0
Checking for Sensors connected to the board
Error Check Sensors - Not Connected
Error Check Sensors - Not Connected -
Software Log 4
07/09/2018 at 09:50 • 1 comment08/07/2018
Add alarm screen with buzzer, sounds buzzer when alarm is triggered !
saves alarm state to eeprom .
-- Stable version - Available in my tindie store !
-Still working on wifi options
Cont .. to do
07/04/2018 at 05:50 • 0 commentsTo do
second menu screen
wifi option
add some more nice features !
Software Log 4
07/04/2018 at 05:49 • 0 comments04.07.2018
Fixed alarm status page and red button - now when a sensor overshoots and meets the set temp an thermal runaway screen appears and buzzer sounds to alert user, then screen moves to a screen to reset the condition using the red button.
I am adding an MQ2 sensor , to detect dangerous gases and smoke. still awaiting sensor but coding is already set.
To test the prototype on my delta printer and next is to do a nice case for it !
Soon this project will be available in my tindie page !
Software Log 3
07/02/2018 at 06:19 • 0 commentsSoftware Log Update
02/07/2018
Added feature to display the menu according to the mode jumpers selected
added caution thermal screen when alarm is triggered
added reset screen and button option to reset the alarm
To test alarm screen
To do
Add another menu screen to include more menu features !
Add wifi option
Add status screen.
Update 2 - software Log
06/27/2018 at 18:05 • 0 comments27/06/2018
Added
-Splash screen 3D Guardian
-Icons for main screen
-formatted the set temp and alarm on screen
-added reading of 3 sensors
- added condition to monitor temperatures per channel with set temp and trigger the alarm
-added the menu feature
-added Instant saving to eeprom of set temp values in case of power cut.
To Do :
- ranges when adjusting set temp
- add jumpers 2 to define 1 or 2 hotends
- add jumper to define id heatbed is installed
- add gui graphic thermal runaway screen when alarm triggered !
- test it in a real scenario !
- make tweaks with icons
Software Log
06/26/2018 at 07:36 • 0 comments25/06/2018
- coded the core and added the splash logo and main screen icons.
- added to monitor 3 NTC sensors
- added set temp value and sensor reading on oled display
To do
- add menu system to edit the max temp and set temp values
- add the conditionals to check for
- add the warning icons and thermal runaway icons
- add buzzer to warn user
- add counter to allow pool before triggering realy
- add save to eeprom to save all details
- add alarm tone if over temp detected.
