1Print the Lily frame and petals from PLA or ABS
print the lily
2Clean up any buggars and filament hairs
3measure the size of the teg and make a cutout in the lily frame
4Use Aluminum to cut parts
5Cutout the circle for the heat absorber
6Trace teg area onto plate
7Cut out the tower segments
8apply thermal adhesive
9epoxy edges of peices for insulation
10Attach the heat absorber plate to transfer tower
