Tidal wave energy large scale conversion
By using vertical force of tidal wave sufficient amount of water pumping possible for hydro power generation.
Public Chat
The horizontal force (along with wind force) on a floating object can be oppose by anchore it properly ( by using four long distance anchors ) so that the vertical force remain almost same. This vertical force is useful. For example It can be very much useful as easily increase this vertical force by increasing the size of the object. This bidirectional vertical force is very much suitable for pumping purpose. By using the vertical force of tidal wave sufficient amount of water pumping possible for hydro power generation.
This is the right way to collect maximum amount of energy from tidal wave. It can solve the demand of world's electricity.
070319 full paper Moniruzzaman(2).pdf
Blue power from blue energy.
Adobe Portable Document Format - 1.43 MB - 03/23/2019 at 20:55
Preview
  • 4 × Anchor Anchor size so that horizontal forces (wave and wind) on the floating object
  • 1 × Big size floating object like big ship. Rejected big ship can be use as floating object
  • 4 × RCC Foundation under the sea Capable to play with vertical force on the floating object.
  • 7 × Water line Size deiends on the size of the pump.
  • 1 × Mini size water reservoir Depends on power station capacity.
View all 6 components
View all 4 project logs
  • 1
    Project idea acceptance
    Very simple technology with logically approved for success with safe and economic way.
View all instructions
Md. Moniruzzaman wrote 04/24/2019 at 07:58 point
Accepted this idea by,
International Conference on Renewable Energy, ICREN 2019, UNESCO, Paris.
https://premc.org/doc/ICREN2019/ICREN2019\_Book\_Of_Abstracts.pdf
Page no. 97
Md. Moniruzzaman wrote 11/23/2018 at 17:51 point
considering the open space available in the ocean, and the tremendous amount of energy it produces, wave power could one day be a viable source of efficient renewable energy
http://www.innovationmanagement.se/2017/07/31/the-5-most-innovative-renewable-energy-sources/
Md. Moniruzzaman wrote 10/26/2018 at 14:22 point
Zero emission, low unit cost, reliable electricity generation possible.
Md. Moniruzzaman wrote 10/16/2018 at 19:49 point
Unlimited source of energy “Ocean tide” can provide low cost zero emission  reliable electricity (unlimited). Tidal energy Is the form of visual mechanical force so it conversion technique shouldn’t  be difficult .
Md. Moniruzzaman wrote 07/30/2018 at 15:08 point
"Blue power from blue energy" - Tidal wave energy conversion project :
Anchored object technique  is the correct method for harnessing maximum energy from tidal wave.
Md. Moniruzzaman wrote 10/26/2018 at 14:26 point
This harnessed force can be use for irrigation purpose.
Md. Moniruzzaman wrote 10/26/2018 at 14:30 point
This harnessed force can be use for liquid loading and unloading from ship.
Md. Moniruzzaman wrote 07/28/2018 at 20:43 point
"Wave power works when other renewables don't, but energy companies have failed to harness this constant source of energy. Now all that is about to change."
https://www.wired.co.uk/article/eco-wave-power-ocean-energy-harvesting-renewable
Md. Moniruzzaman wrote 07/28/2018 at 20:35 point
"Ocean tidal energy has the potential to provide unlimited  gigawatts of power worldwide, "
https://www.technologyreview.com/s/537656/why-hasnt-tidal-power-taken-off/
Md. Moniruzzaman wrote 06/24/2018 at 21:38 point
This is a very easy technique to harness energy from ocean tidal energy as already running some small projects. Capacity can be increase as required by increasing the size of the object and pump very easily. Expensive waterproof devices not required for this easy technique.  Compare to the other hydro power stations dam, big reservoir,  big catchment area not required so cost effective.  Also other facilities will be there.
