1Schematic analysis
As we can see, default schematic is 3-bit wide, but we can easily change it to 4-bit mode
2Adder assembly and checking
3Control logic wiring
4Solder memory block
four 4-bit cells and decoder
5Assembly all blocks to each other
6Mount control panel and finish building
7Create new case and scrap project before it's done :(
Such a nice project ... t want to build one too ... i worked in my company time with relais ... especially the typ ESK with 2ms time .... but i forget to hold equipment from these past times ... now i will try it with other small reedrelais ... ok good luck an succes in your further projects ...
carlo SA2KHG
2ms switching time is too slow... Reed relays can switch in 700us, but as I found on reed relay computer - this is not fast enough too but already can create 500Hz full adder.
