1Want to make yours PCB, which will glow on mW-oven's glass? Follow these points:
1) Order PCBs, using Gerber files (i.e. at www.jlcpcb.com)
2) Order all components, mentioned in BOM (i.e. at https://www.digikey.com/ or https://eu.mouser.com)
3) When you got both PCBs and all components, print BOM and Document for assembly.
4) Grab soldering iron and solder components into PCB, using printed documents as reference
5) ...
6) Well done! Now grab assembled PCBa, stick it to your mW-oven, and cook some food!
P.S> all files can be found in project's file section.
Jurist
