Steel wool electrodes
07/14/2018 at 17:02 • 0 commentsTo use steel wool that used for washing utensils for making electrodes.
Adding nutrients
07/11/2018 at 12:43 • 0 commentsI just poured a shot of coconut water. One day later. It seems voltage increases. Perhaps some nutrients should help.
But still without current. And there is some bubling.
Will it be layer as in Winogradsky column ?
Steel wool for electrodes
07/09/2018 at 16:53 • 0 commentsI think that graphite felt or even homemade activated charcoal are expensive (or hard to manufacture) for electrodes. I could use cheaper off-the-shelf steel wool. It possible to use it for electrodes. And I should add micro algae into cathode too. It should increase power. I could buy chlorella or micro algae from e-commerce stores in Thailand (mostly sell to moina breeder).
MFC Proof of concept
06/30/2018 at 12:28 • 0 commentsFor proof of concept. I conducted experiment for mud MFC with graphite felt electrods for few weeks. Open circuit voltage is about 0.14 volts. No closed circuit current. Next step is to find new electrode material should be cheaper.
