Captain's Log 4: First Design Drawings
07/16/2018 at 21:02 • 0 commentsWe have a bunch of different design ideas floating around (get it) for F.L.O.A.T.I.B.O.I, and here's an initial one.
Captain's Log 3: Power System Research + Calculations
07/12/2018 at 20:58 • 0 commentsOne of the key components of F.L.O.A.T.I.B.O.I is that it is meant to be powered by renewable energy. There is no shortage of energy sources out in the ocean - why let it go to waste?
As mentioned in our details section, F.L.O.A.T.I.B.O.I is meant to be powered by a renewable energy system. This system would likely be specific to F.L.O.A.T.I.B.O.I, but the concept could be extrapolated and scaled to any marine robotic project.
We primarily plan to use wave energy, solar power, an wind energy. There are numerous instances of USVs (Unmanned Surface Vehicles) using these sources of power already (you can check out some examples in our landscape analysis file!).
Once we determine what motors we plan to use to drive F.L.O.A.T.I.B.O.I, we'll have a much better idea of the power footprint. Until then, a tentative power system parts list:
Lithium Polymer BatteriesSolar Panel(s)
Charge controller(s)
Wave power foil
wind turbine(s)
One current idea is to have the wind turbines be able to rotate 180 degrees from the air into the water on less windy days to take advantage of any turbulence in the water from F.L.O.A.T.I.B.O.I's movement, movement of plastic trash, etc. Any thoughts or suggestions?
Captain's Log 2: Updated Detail Section
07/12/2018 at 20:53 • 0 commentsBased on some recent research for the project - just updated the detail section! This should provide more information, context, and motivation for the F.L.O.A.T.I.B.O.I project overall.
Captain's Log 1: Landscape Analysis
07/12/2018 at 19:37 • 0 commentsWhen we came up with the idea for F.L.O.A.T.I.B.O.I, we wondered if anyone else had already made something similar and make sure that we accurately scoped the problem. Enter the F.L.O.A.T.I.B.O.I landscape analysis - the first step of our project! You can find it in the link below.
