1. Adding a Voltage divider network to measure the battery voltage and monitoring the data on Smartphone.
2. Power Consumption optimization.
3. Separating the Solar Panel from the main enclosure to get more accurate weather readings
4. Making a custom PCB for the circuit.
5. Over The Air ( OTA ) sensor calibration
6. Option to add more weather sensors like wind, rain and light sensors.
