Change the input PWM signal to another PWM signal output with an Encoder
GitHub repository this code: https://goo.gl/93mw2v
I thinking to create a PCB for my project.
A lot of FabLab or Hacker Space has a home made laser cutter, and i suppose they have the same problem for setting the ( PWM ) power for the cut.
Stay tune!
View project log
Abel
Németh József László
Daphne
Mrinnovative
Yes, delete it Cancel
You are about to report the project "PWM to PWM", please tell us the reason.
