Bypass
A project log for Precision current generator
A useful tool that injects small currents into your circuits, below the range of your usual lab PSU
yann-guidon-ygdesYann Guidon / YGDES • 07/13/2018 at 00:26•0 Comments
I added a bypass switch.
It disconnects the outputs and shorts the generator to 0V, so you can check that everything works well (for example, if some saturation is suspected). You don't need to short the output with a wire to set the max current :-)
Because this is how it looked before :
... less elegant, right ?
