The PWm charge controller have combine feature of energy meter and charge controller.The charger can automatiaclly 6V or 12V battery and set all the charging set points accordingly . You need not worry about any change in the software.
Specification of charge controller :
1.Charge controller as well energy meter
2. Automatic Battery Voltage Selection (6V/12V)
3.PWM charging algorithm with auto charge set point according to the battery voltage
4.LED indication for the state of charge and load status
5. 20x4 character LCD display for displaying voltages,current,power,energy and temperature.
6.Lightning protection
7.Reverse current flow protection
8.Short Circuit and Over load protection
9. Temperature Compensation for Charging
Electrical specifications :
1.Rated Voltage= 6v /12V
2.Maximum current = 10A
3.Maximum load current =10A
4. Open Circuit Voltage = 8-11V for 6V system /15 -25V for 12V system
Open Green Energy
George
Sagar 001
