21Use enough glue to affix the bottom cap in place.
22Cure the glue; I used a lamp to speed things up.
23Prepare to affix the coil assembly in place. I used this glue because it is a toughened version of silicone and easier to work with than hot glue.
24Glue the coil assembly in place; I only glued the top half in this picture, though I ultimately glued around the entire assembly.
