Making the series of the cells
07/16/2018 at 14:49 • 0 commentsA single cell produces about 1.5 V. We are going to make 3 cells. Then rape a tape around them for fixing. keep in mind carbon has positive charge and magnesium has negative charge. For making series we will connect carbon and magnesium with wire and only leaving the first and last terminals. First and last terminals are our out put where carbon side has positive charge and the magnesium has negative charge. our total out put would be about 3.5 V. Where we can run a LED. if we increase an other cell then can charge a cell phone in very small ratio. Because these are very low amps. For real time charging cell phone we need big size of carbon and magnesium.
Fixing the anode and cathode
07/16/2018 at 14:19 • 0 commentsNow we have to fix the carbon and magnesium in the cape of jar. which would be like this.
Setting the Magnesium Ribbon
07/16/2018 at 14:10 • 0 comments![]()
From magnesium ribbon. We will make our electrode like this
Main things We need
07/16/2018 at 14:00 • 0 comments![]()
carbon and magnesium are our main components for making the battery. These are our anode and cathode.
Wasim Sahu
